how do you remember?
chrisw91
i need something to help me remember wiring configurations. series from parallel. like for voltage and ohms and amps, people use the water valve as a way to remember. any good ideas on how to remember series from parallel. and also how to do the math on a final ohm load of multiple subs. i basically want to not have to look on rockfords website everytime i want to know.
I guess you can remember series configuration like a series of loads, where the current must flow through each load to complete the series.
When things are parallel the current will split and distribute through each load.
I hope that helps you out.
series you add the load of all the resistors, 2 4ohm resistors in series delivers a 8ohm load...
parrallel you divide the resistance (in ohms) by the number of resistors. 2 4ohm resistors in parrallel is simply the resistance (4ohms) divided by the number of resistors (2) so final is 2ohms. works regardless of quantity.
20 1ohm resistors in series has a final load of 20ohms
10 2ohm resistors in parrallel is 2/10, or a final of 0.2ohms
Don't forget about series-parallel as well. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
yup...like tying your shoes. you either know how to do this stuff and understand it, or you dont
and don't feel bad if you don't I once had a guy try to sell me a dual 1ohm sub because my amp did rated power at 1ohm, i spent half an hour trying to explain to him dual 1ohm is .5 or 2 final.
so if you can't remember, stick to the rockford website, whatever makes it easiest
parallel the wires never cross, thus being "parallel". and parallel cuts the ohms in 1/2
series, there is a "series" of + to - before it gets to the amp. series multiplies ohms x2
That only applies when the reisstances are the same and using two speakers/subs...
chrisw91
chrisw91
phoenix, az
qkassidyw
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
