chris229, thanks for the info. I id what you said and I have a problem. I put in Diamond Hex s500 components for the fronts and left my stock for rear fill. I have a JL W3 10" sub in a fiberglass enclosure and a JL500.5 amp to run everything.
Here is the issue. My stock stereo had the factory amp in the trunk. I removed he factory amp and made a plug to fit the factory harness. The point is I didn't mess with any factory wiring.
The noise I have seems to be coming from the front channel outputs from the head unit. I ruled out the amp and the RCAs. It doesn't make sense, I didn't mess with the factory wiring but it seems the factory front channels outputs from the head unit is the source. I had no noise with the factory system.
If this is confusing, I can explain better.
TIA (again)
