how do i remove this?
well if you have that piece of the dash out on the sides of the radio directly behind the holes in it you should be able to see the metal clips that are holding it in. They are kinda spring loaded thingy's. Just push in on them and slide the radio out through the front of the dash.
The 8-10" piece method is the best, just once they are inserted and you can feel that they are in the clips, pull the two piece into a spreading outward motion while at the same time pulling towards you and the deck should slide right out.
Most people forget that they need to spread outward to release the inside latch's......//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
TWF
TWF
enterprise, ms
DARKHART
