how do I determine degree of angle?
samger2
Ok...I'm on a new idea now...I want to build a box that sits flush against the back portion of my rear seat in my Cherokee and fires toward the rear of the jeep...the back seat is angled...but I don't have any tools to determine the degree of angle. Is there anyway I can do this without buying a tool?
Time to bust out the trig. I had to review how to do it, since I've been out of school for so long. Basically take a square and use that to figure out the height to where it is at the back of the seat top. Then measure the distance from that "plum" line to the back of the seat bottom. That should give you a triangle with the height and base. Then you can figure out the hypotenuse easily and go from there.
Ok...my brain is mush.
This box isn't the box I'm using, but has the exact degree of angle that I need. I own this box and it fits perfectly in the angled area I'm dealing with.
Because it's 9:30pm and I don't feel like leaving the house and I'm trying to do some calculations at my computer before I start building soon.
But I'm sure I'll spend the $1 it takes to get a protractor before I actually start my project.
SohCahToa; Sine(theta)=opposite/hypotenuse, Cosine(theta)=adjacent/hypotenuse, Tangent(theta)=opposite/adjacent.
To find that angle, you divide the height of the triangle (14"), which is our OPPOSITE side from the bottom angle we are measuring, by the distance the slant face covers (it would be your bottom depth minus the top depth, or 5"), which is our ADJACENT side. This quotient is 2.54... . The inverse tangent of this is 1.19 radians, or 68.55 degrees.
Tangent(theta)=14/5.5
arctan(14/5.5)=68.55 degrees
edit: top angle:
tangent(theta)=5.5/14
arctan(5.5/14)=21.45 degrees
the other angle is obviously 90 degrees, and 90 + 21.5 + 68.5 = 180 degrees
samger2
samger2
Blacklick, Oh
maldecido33
