How do i bench test
Do you have a giant power supply, a precision resistive load, an o-scope, and a purely resistive speaker? If you don't have the first 3, you're not going to get a number that means anything. If you don't have the last one, any number you get won't matter anyway once the amp is installed. If you're playing music with the system it becomes even more irrelevant.
The first 3 will run you more than your car. The last one doesn't exist.
i would say ask SM, but we all know you can't.
he would have hooked you up for cheap too...//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
u can do basic testing with an oscope, a function generator, and some non inductive resistors.
note, there are some factors that limit the absolute accuracy you will be able to achieve
thee equipment being used is quite expensive though... I used to be able to use these things at the EE buildings at my old school to avoid having to buy it.
You are forgetting the most important part. THE BENCH! duh. J/K
You need a calibrated dmm and clamp meter for measuring the output.
You also need a power source that will feed steady voltage for testing, a power supply is the most commonly used but a battery bank and a charger with selactable charging level can be substituted for larger power demands.
A few key points to keep in mind.
a. Most manufactures tests and so called birth sheets are done with a resistive load. The load doesn't change and is useless in determinig real world performance.
b. A more accurate method of testing a amplifier to determine what its output is in a install is to test it in the car with the drivers and the enclosure it is powering. This test is a reactive test, and will only tell you your output at a certain frequency. If you feel really motivated you can test at a range of frequencies based on what you usually listen to. The load on your amplifier may be 1ohm when it is not playing , but when it is played and depending on how the drivers react with the enclosure your ohm load will rise lessening the load on the amplifier and making it deliver less power than advertised.
c. Bench tests and birthsheets are BULLSHIT! A convient way for manufactures to make you feel better about buying their product. A piece of paper with a inflated power# that will most likely never be duplicated in your car.
If that is so, then is it not correct to say that an amplifier with a higher birth sheet rating will supply more power than a lesser amplifier, given the same enclosure, subwoofer, install, etc.?
So even though the given power cant be duplicated (because of a speakers various inductances and capacitances), it is still a reliable way to compare various amplifiers??
If so, then I wouldnt consider bench testing "bullshit".
Bench testing for the sake of " my amp puts out 3415 watts" is Bullshit.
Published test results that advertise a certain output power are Bullshit.
For general product comparison bench tests do have value, but have little relevance to real world performance.
bad03ranger
Get Some *****
bad03ranger
Reidsville, North Carolina, United States
helotaxi
