How exactly is a rainbow made? How exactly does the sun set? How exactly does a posi-track rear end on a Plymouth work? It just does.
well, the sun refracts from the water droplets in the air. different wavelength (colors) can bend to different degrees, so the angle relationship between you, the sun, and each droplet will allow you to reprieve only one color, or none...
the sun doesn't set, the earth turns so that you no longer ave a visible path to see the sun. (colors come from the sun passing through a greater amount of atmosphere, filtering further the higher end of the light spectrum)
typically, cone clutches are on the back of the 2 side gears, spring-loaded apart, pressing these clutches into the housing. the greater the differential force present, the more the spider assembly pushes out on these side gears, again applying greater pressure on the cone clutch.
i would say more modern seats are starting to implement thermocouple elements. thermocouples not only make electricity from heat, but also super-cool with enough power in the right direction. i cannot verify 100% on these newer gm's but that was one of the more recent applications. one single element gives you both heat and cool.
