hey new site is up
If they could make it in colors it would be a sick underbody kit. Think, you'd never really have to worry about breaking it, it would be really easy to hide.
sounds intriguing. So say you buy a 8.5"x11" sheet and cut it to various shapes and pieces, does each piece have to be connected to one another? or does each piece needs its own power source?
Once you cut a piece off of a sheet it is no longer useable since there is only on wire connection.
Well, you can light it back up if you had some conductive adhesive or can generate a large electric field around the panel.
EL is designed to be small and not too bright. CeeLite pioneered the 3 wire LEC panels. There is a ground shield that reduces EMF on the panel and allows it to be driven brighter and larger panels to be produced without killing the life and without risk of electric shock.
The LEC panels can actually be driven to 600 cd. even though 100-200cd is the standard. 90-100 cd is the average brightness of a laptop screen.
E.L. is really only designed for 50-100 cd, some EL can be driven to 200 cd but the life is cut down dramatically and the EMF is quite large.
So basically it is EL, but higher end. RazorLite and CeeLite use the best phosphor in the world as well as other materials like ITO. If you look at your cell phone buttons, this is EL, very small and only 50 cd.
Watch CNN, ESPN, NBA TV, NFL TV, and a few others and their sets are decorated with CeeLite LEC. Much larger and brighter. even 12ft panels can be produced.
large electric field? like a magnetic field?
what do you mean by this.
Electric field and magnetic field are different.
Electric field is like whats under large power lines. A magnetic field is like whats in an MRI.
So if you carry a panel close enough to high voltage power lines, they will light up.
Flowing current creates an electromagnetic field. Im not following how you are trying to differentiate an 'electric field' and a magnetic one.
The electric field and the magnetic field are tightly interlinked, in two senses. First, changes in either of these fields can cause ("induce") changes in the other, according to Maxwell's equations. Second according to Einstein's theory of special relativity, a magnetic force in one inertial frame of reference may be an electric force in another, or vice-versa (see relativistic electromagnetism for examples). Together, these two fields make up the electromagnetic field, which is best known for underlying light and other electromagnetic waves.
Ed Lester
SPL and Lights
Ed Lester
Philly Pa
Ed Lester
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
