HELP on VOLUME for e12kd4
TRDevelopment
hello i need help on the enclosure volume for an e12kd4 ( ONE ) that will go into the wheel well. i already calculated the volume 1.3 is the max volume for mr wheel well. IS THIS ENOUGH FOR AN E12Kd4? if by anychance i go ported is the volume still ok=. and how big will my port hole be?
PLS BADLY NEED THE HELP!
if your only using one edk, and want to give it 600 watts, then im pretty sure you should get a 4 ohm and wire it in paralell to itself. +/+, -/-
dont judge your purchase off that, but im almost posstive thats how you would produce a 2 ohm load (the 600.1 puts out 600 watts at 2 ohms)
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
If you have an OEM radio and amp, chances are that one has bass reduction as the volume rises to protect the paper cones from tearing apart. So if...
6
80
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
121
TRDevelopment
TRDevelopment
Bronx, NY
Savant
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
