help how to set crossver on amp
  • 2
i still trying to learn how to set crossover settings on amp
High pass means that only high frequency signals will pass to be amplified. So in most amps high pass means midrange and tweeters. So if you have 2 amps, one for mids/tweets, and another for subs, you want to set your high pass at 80 to 100 hz on the voice amp. The reason for this is so your voice speakers do not play very low bass notes which could damage them. And in setting them at 80 to 100 hz, you can hear better detail and play them a bit louder.
Now low pass is the total opposite of the above.
If you have components that came with crossovers, it would still be of benefit to set the amp's high pass crossvovers at 80 to 100hz.
237
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
257
497
biglion
biglion
nahsvlle tn
slater
    May 2, 2024
slater
    May 2, 2024
