hello from Nebraska
  • Thread starter bigjigs
  • Replies 0
  • Views 678
bigjigs
Hello everyone! I just wanted to stop in and say hi before I started posting ?'s in the forum. I'm from Fremont, NE and am married with one child. I just started getting back into car audio and have enjoyed building my own systems and helping friends with there's. Right now I have a 97 Dodge ram diesel turned up to about 350-400ish hp. I've replaced the factory speakers with pioneer replacements and pioneer headunit. I built a fiberglass resin dash center pod that houses 2 3.5" 2 ways driven by a old alpine 20w x 2 amp. I built a sealed mdf sub box that houses a 15" old rockford punch dvc. The box is bolted to the factory center seat brackets and the sub is flush mounted to the bottom pointing at the floor. I had just enough room to fit the 15 inside the 4 seat brackets. I recessed the sub to ensure it would fit and the surround would not rub the brackets. I used 3/4 mdf and doubled it for the sub face(baffle?) to ensure It would be solid and I sunk the bolts inbetween the two sheets so there would be no air leaks around the bolts. I built cupholders into the top of the box because I removed my factory ones from the upper dash and mounted my boost/egt guages there using lexan. They were in a poor location and would spill a full drink on the face of my headunit on turns. I used a roundover bit to round the edges of the box and the inside of the cupholders. I mudded and sanded all imperfections then painted and urethaned the box. the inside is reinforced and has polyfill added. Was running the sub fine for about 2 weeks with a 500 rms alpine amp when I cranked it one morning cold and cracked the cone. It cracked about 2 inches in from the outter edge and buckles when turned up until it gets distorted and the amp goes into protect. I also had the gain cranked on the amp and I'm sure the distortion wasn't good on it either. Again hello and hope ur bass hits crisp and clean!
bigjigs
bigjigs
Fremont, NE
bigjigs
