Head Unit swapping, have question
  • 4
cactusjac7
Hey everyone, im new here so forgive me if im posting in the wrong forum. I have a question regarding my current set up in my car. I have an Alpine CDA9886 head unit in my car. Its a good unit with Ipod hook up and also has a 6 disc changer (also Alpine) mounted in my trunk. The unit has bluetooth capabilities but the adapter was never installed. I want to add the bluetooth but the adapter costs $250.
My question is if i replace the head unit is there anyway I can still use the 6 disc changer. I was thinking if I get another Alpine unit it might still work but I feel swapping out the unit with a bluetooth enabled unit is a much cheaper option rather then buying the bluetooth adapter.
Any help would be greatly appriciated and thanks in advance!
some Headunits can use a second auxilary to run changers. Im sure you can find a Unit that does all you need, but I was in same boat last year either spend 175 to get 150 HU blue tooth or 200 for 80PRS so i got the 80 PRS
293
635
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
719
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
876
cactusjac7
cactusjac7
Wall, NJ
tommydh
    May 24, 2024
    May 23, 2024
