What is Class 2 databus ?
Affects of removing Class 2 from your vehicle
Factory Deck Removal Process
ABS Concerns
Affected Vehicle List
What About OnStar ?
New Peripheral Interfaces Available
The Class 2 system is a Serial Data Link used by GM in its vehicles, and is based on the SAE J1850 protocol, which is widely used in the U.S. It is through this data link that the body control module (or BCM) receives information and commands that are essential in determining its mode of operation.The BCM is connected, through Class 2 wiring, to the instrument panel cluster (IPC), the powertrain control module (PCM), the data link connector (DLC) and the radio.
Recently GM has now included the driver’s door module, passenger’s door module, rear seat audio controller, vehicle communication interface module or OnStar®, steering wheel audio controls, rear seat entertainment (RSE), CD changer, radio, DVD/Video, amplifier and XM radio as part of Class II. Since these new modules are part of the audio system and security system, you are now hearing more about Class II.
Connected to this same data wire is the Body Control Module (BCM), Powertrain Control Module (PCM), Transfer Case Shift Control Module, Heater & A/C controls (HVAC), Inflatable Restraint Sensing and Diagnostic Module, Theft Deterrent Control Module, Memory Seat Module, Drivers Information Center (DIC), Key/Lights/Seatbelt Chimes (most vehicles), Instrument Panel Cluster (IPC), Suspension Control Module, Electronic Brake Control Module (EBCM) and other modules.
Affects of removing Class 2 radio from your vehicle
Vehicle Customization Menu Options:
( Most Cavaliers, Sunfires and other base models do not offer most, if any of these features.
Check the vehicle owner’s manual to see available features. )
Displays current settings
Oil life monitor reset
Tire inflation monitor reset
Delayed headlamp illumination
Automatic door lock and unlock
Remote visual/audible verification of remote lock/unlock
Enable/Disable content theft
Enable/Disable trunk lock shock sensor
Short or long horn with remote lock/unlock
Key fob transmitter programming
The radio is used as a control panel to communicate with the vehicles computer for the customization of certain “convenience features”. All features work and remain at current settings with the factory radio removed, but can only be customized and/or reset by an authorized service center. More important than the above features and chime, there is no switched 12vlt. power supplied in the radios plug, so it will need to be sourced somewhere else such as the factory fuse panel. A 10A to 30A fused accessory power source is recommended. Depending on the vehicle there are several choices in the factory fuse panel, such as the sunroof or windshield wipers.
What About OnStar ?
When you remove a radio from a vehicle with OnStar ( application list below ) you loose the speaker capabilities of the OnStar system. Ventura & Metra have teamed up to make a peripheral interface for the OnStar system if you want to remove the factory radio and retain the functions of the OnStar.
Frequently asked questions
Do all these modules communicate at the same time?
Yes they do. Each module on the bus has its own ID number and is sent out every two seconds as a state of health message (SOH) to let other modules know that it is present. Every module sends information to other modules when needed. When the ignition is first turned on, there could be as many as 100 or more messages sent on the data bus from various modules within 1 or 2 seconds.
How can all the modules communicate at the same time and not interfere with one another?
Well first, all the modules have a Data Link Controller (DLC) chip with and internal or external transceiver physically connected to the data bus. And second, each module is assigned a different level of priority. The DLC is the key to the Class II bus. It is designed to send and receive data depending on priority. When each modules sends information over the data bus, they also check to see if there is other data activity on the bus. If that module sees other data while it is sending data and it has low priority, it will stop sending and try again when the data bus is inactive.
What happens if one module goes bad or power is disconnected from it? Will it load down the data bus and disable crucial control modules like the PCM or BCM?
Again, the DLC chip or transceiver is the key. It is designed so that even if power is interrupted or it damaged, it will not affect the data bus. So lets say if the radio power was disconnected but it was still connected to the data bus, it will not interfere with any other control module’s communication on the data bus.
Does your product use the DLC chip?
Yes they do. We incorporate it in our products to insure your safety when you drive your vehicle. You may pay alot more for our products for Class II, but is your life or family worth saving a few dollars?
