HCCA 15d
Sensitivity: 87 dB
RMS Power Range : 2000 Watts
Peak Power Handling: 4000 Watts
Impedance: Dual 2 Ohm
Diameter: 15 Inch
4” copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
Continuous power handling will be 1500W (under rated)
Burp power in excess of 5000W
X-Max estimated at 30mm (total travel 4” peak to peak)
Field Replaceable Cone / Voice coil / Spider Assembly
Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
Enhanced voice coil cooling system (forced convection – aluminum heat sinking – shorting rings to reduce inductive heating)
jrock
jrock
mississippi
misfit138
