Guide for beginner convert video to zune
jane1043
12
fg
Guide for how to convert AVI, WMV, MPEG,RM,ect to zune
This guide will tell you how to convert AVI, WMV, MPEG, RM, Divx, MOV,XviD, , RMVB, ASF, MPG to Zune.
Notice:
Before convert convert AVI, WMV, MPEG, RM, Divx, MOV,XviD, Youtube, RMVB, DVR-MS, FLV, ASF, MPG to Zune, let's check the format limitations which the Zune plays.
* Zune Video: unprotected MP4 (MPEG-4), H.264, WMV up to 320x240
pixel, 1.5Mbps video bitrate, 30fps, 192Kbps audio, 44.1kHz.
* Zune Audio: MP3, WMA, AAC up to 320Kbps, 48kHz sample rate.
Related download
* To convert RM/RMVB real media files to Zune, Maybe need to install Realplayer:
http://www.real.com/freeplayer/?rppr=rnwk
* To convert ASF to Zune, Maybe need to install Windows Media Player:
http://www.microsoft.com/windows/win.../defaurlt.mspx
conversion tools:
Pavtube Video to Zune Converter is the software especially for playback on Zune player to convert the popular formats to the formats Zune supported. It allows you to edit the videos by trimming and crop function, merge the videos into a large and single one, and capture pictures from the videos for storage on your own PC. Its customized design meets the requirements of the Zune-lovers pursuing the practicality and the specialty. In addition, the product provides the advanced settings like bit rate, frame rate, video size, etc. for those who wish to make more control to the video. Moreover, friendly interface makes you operate it expertly for the first time without the troublesome process.
1. Download the latest versions from office website: http://www.pavtube.com/video_to_zune/,and run Pavtube Video to Zune Converter and you will see its main interface.
2. Import the videos to the file list by clicking Add button. Then you can edit the list using the buttons under the list.
3. Open the profile drop-down bar to select the target conversion format for playback on Zune player. After this, please open output drop-down bar to specify where to save your converted files.
4. Previewing the video is a good choice for you. Under the preview window, you can click the button to capture the still pictures to save on your PC for enriching the picture collection.
5. Edit the videos
Effect:
Adjust brightness, contrast, volume for video and audio. In addition, you can tick to modify the image effects in flipping and deinterlace.
Trim:
Drag the slider or set the number manually to choose the starting time and the ending time. You can gain the selected time phase for enjoyment.
Crop:
Open the drop-down list to select which edges to be cut off. Drag the frame-mark to specify the region you want.
6. For better effects, clicking setting button can satisfy you. Tick to select which part to modify, video or audio. One click for the parameter can make the triangle button appear. Hit it then amend the parameter.
7. Click the merge button to create a single file. If you wish to reduce the trouble of resetting, hit apply to all button.
8. Start to run the program by clicking the button. After this, you can confirm the converted file on your PC by hitting open button. Here all the preparing work is finished. Then you can transfer the converted file to your Zune player for enjoyment.
jane1043
jane1043
fg
jane1043
