reclessantics
If its possible, would it be best to drill straight through the cab, (through the floor) and anchor bolt my ground wire to the frame? I wouldn't worry about it if it wasn't a possibility. Its close enough to my distribution block, and amps, that total, from the spot id ground it, to the dis block, and then out to the amps, my ground wires, from amp, to frame, would be under 3 feet.
thanks
kyle
thanks
kyle
