I have a high pitched squeal coming from my speakers only when the RCAs are connected to my amp. When I use a Y-adapter and my ipod, it's fine. I've read that this problem is almost always caused from the grounding of my RCA cables.
How to I go about grounding them?
I really don't want to take out my head unit because I have to remove my dash and it's a pain in my a$$.
Can I wrap wire around the negative part of the RCAs at the amp and run that wire to the chassis?
Can I use the same ground as I do for my amp ground on the chassis?
