Good Equalizing?
Echo42987
I was curious to what would be a good EQ setup to add to my system as I would like to fine tune it some more.
You can see the equipment that I have by looking in my sig and on my Avic, it doesn't have much of an EQ process so I would like to narrow it down some more. I currently am running a the 4 channel to all 4 speakers and would like to keep it that way.
Thanks for the help guys as I know some of you should have some good input! //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
-Nick-
How the hell does that thing work? Never even heard of it before. Is it an older modeled unit?
GREAT unit! Basically you plug your rca's from your HU into the box and then run it off of the unit. You can adjust real time on the screen, make multiple settings change the tone, its also a preamp so you dont' have to use the gains on your amp.
Time alignment is probably just as important as EQ'ing.
That Symmetry unit doesnt have TA.
You would need to look for an RF 360.1 or 2 (.2 has twice the EQ) or an Alpine H701 in order to get TA.
Echo42987
Echo42987
Antioch, IL
Pl8er
