Good Deal??
get it. and BTW its a 5 channel amp.
RMS @ 12.5v
2 Ohm Load 320 w x 1
70 w x 4
4 Ohm Load 160 w x 1
35 w x 4
Bridged 4 Ohm Load 140 w x 2
Dynamic Power 14.4 VDC
2 Ohm Load 490 w x 1
100 w x 4
4 Ohm Load 245 w x 1
50 w x 4
Bridged 4 Ohm Load 200 w x 2
k, i just wanted everyones advice first, whats the most power each speaker can recieve from this amp?
lol that is true. Not a real big feat to figure out. You can always do a search on the net and get the specs that way too. Pretty easy and you dont have people flamin you when you ask a silly easy question!
well it say 70W and 100W x 4. which one do u go by? and is it a good deal?
Actually read the ratings and they will give you all the information you could want on that amp ~
get it. and BTW its a 5 channel amp. RMS @ 12.5v
70 w x 4
35 w x 4
100 w x 4
50 w x 4
Read that to mean if you feed it in 12.5v DC current it will do the following:
@ 4 Ohms ~
35w X 4 + 160w X 1 on the sub channel
@ 2 Ohms ~
70w X 4 + 320w X 1 on the sub channel
If you up the input voltage to 14.4v DC current it will do the following:
@ 4 Ohms ~
50w X 4 + 245w X 1 on the sub channel
@ 2 Ohms ~
100w X 4 + 490w X 1 on the sub channel
If it works 100% shoot yeah it's worth what your friend is asking.
solo33
solo33
iowa
Prowler573
