going to ATTEMPT my first glassing project....
cjj2d
I have read a crap load of the tutorials/how to's, and am finaly going to try it. I am going to start with some kick panels for some 5.25 mid range drivers. or perhaps panels for a 6.5 mid bass if room allows. (should I put the 5.25 in the panel and 6.5 midbass in the door or vice versa?)
any last minute tips before I head to home depot? anything I might be forgetting to get???
This is the list I am using to get at HD....
These are the materials you will need; you can get just about everything at Home Depot:
- A gallon of fiberglass resin
- A coupe extra tubes of hardener
- 2 or 3 packages of fiberglass mat
- A big box of disposable gloves
- Lots and lots of cheap brushes (use bristle brushes, not foam)
- A dropcloth, painters tarp, or garbage bags
- A Dremel with a fiberglass cutting bit (#542)
- Painter's tape
- Fleece
- Spray adhesive/liquid nails/epoxy/hot glue gun
- Wood dowels
- Sandpaper
- Body filler
- A mold release agent (WD-40, vaseline, a non-stick cooking spray, astroglide, petroleum jelly, etc)
- Carpet or vinyl or paint and primer
- Coarse thread drywall screws
Thanks, wish me luck. oh yeah about how much will all this run?
- Painter's tape
- Fleece
- Wood dowels
- Sandpaper
- Body filler
probably around 100$...give or take 20$. good luck!
i wouldn't worry about the extra tubes of hardener.....being ur first time, it would be better if u mixed the resin "cooler"..give ya more time to work with it. takes a touch longer to dry, but it will also let ya work a lil longer with what u mixed.
good luck, and don't forget the pics!
wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee //content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
i have always had a liquid hardener???? didn't know you get tubes of it???
cjj2d
cjj2d
Murfreesboro
lotas
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
