Gawd Dam PS3 Internet issues
No...Modem is located down in the basement and dont have an ethernet cable:crap:
any way you could get ahold of Brad Johnson? I hear he is good with these types of things, he won't be going anywhere after season's end so he should be free.
//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
have you tried disabling the security to see if you can connect? if so then the problem is likly w/ your security
Yea...I tried it many times with my Secuirty on...didnt work.
Went into my modem settings, turned WEP off, made it an open network...and it still wont connect...Now when I did this, when I went into my ps3 and went through the setup wizard...It asks me my ssid, i confirm it. Asks me security, say none. I then get a message saying " a connection to the access point could not be established. Check the secuirty settings for the Wireless LAN(8013013E)
make sure you have it so your settings say it accepts wireless G and Wireless B connections, i forget which one the PS3 is, i think G, but set it to both just in case.
You might be able to get some help here http://www.portforward.com/guides.htm
But the way I set mine up was I assigned my ps3 an IP address on the pc first, and set that one up on DMZ. DMZ is basically placing that IP address outside the firewall if I understand correctly. That way you won't have connection issues playing Multiplayer games.
I am not too familiar with that router, so I would have to look up how to do it. If I come across anything I will post it here.
To get the IP address, on the pc go to start/run/cmd and type in IPconfig
It will then give you a bunch of numbers and all of that. Also to go into the router settings, pull up a IE window and type in 192.168.1.1 or 0.1. Might be different for the router you have, but that's what I need to look up.
To be honest...That went way over my head:laugh:
Im not to savvy with Internet configuration
tEh koRnDog
tEh koRnDog
Buffalo, NY
TurdFergueson2
