Excellent condition like new condition: I have the orignal box and instructions PLUS a customer made fiberglass enclosure. This product retailed for $1200 and has not been used since 2000. I am not looking for trades besides a VERY good SQ amp or an installer in NJ that would help in fabercation of my new system. Please send any inquiries to Josh.Baptiste@gmail.com
FEATURES:
• Analog and digital inputs and outputs allow unit to interface with any audio system
• Balanced high-frequency power supply
• Power and signal grounds floating for complete noise isolation
• C-LOCK™ jitter reduction circuit
ANALOG INPUT SECTION:
The DEQ30 uses an 18 bit balanced delta sigma analog-to-digital converter with 128 times over-sampling. It accepts both RCA and Balanced (Mini XLR™) inputs. Left and right input sensitivity adjustments are fully variable and independent.
DIGITAL INPUT SECTION:
The digital input section uses a professional grade SPDIF receiver. The DEQ30 supports 44.1 kHz and 48 kHz sampling frequencies and both Toslink and coaxial digital inputs.
OUTPUT SECTION:
Analog output is via unbalanced RCA or balanced Mini-XLR™ jacks, with 4 volts RMS output (8 volts RMS in balanced mode). Digital output is supported via Toslink or coax jacks. 30 bands of equalization are set to the exact frequencies on 1/3 octave Real Time Analyzers. Left and right channels can be adjusted individually.
ANALOG OUTPUT SECTION:
• 1 bit Phillips D/A converter with 18 bit resolution
• 192 times oversampling
• Low total harmonic distortion
• No crossover distortion
• Digital De-emphasis
• RCA and Balanced (Mini XLR™) Outputs
• 4 Volts RMS output (per phase)
• Signal-to-noise ratio greater than 100 dB
DIGITAL OUTPUT SECTION:
• Professional grade SPDIF transmitters
• Supports both Toslink and coaxial digital formats
• Output frequency 44.1 kHz
FEATURES:
OUTPUT SECTION:
