Gauging interest in a group buy
here's the little spec for all of them
5.25- Amazing bass in a compact package! This one-of-a-kind 5-1/4" subwoofer has an impressive 9.25 mm of Xmax. A wide roll surround, raised flat spider, and large 1-1/4" 4-layer voice coil ensure impressive bass performance and high power handling. The vented pole and vented spider allow good airflow around the coil to improve heat dissipation and reduce compression. The ultimate miniature subwoofer driver!
Specifications: Power Handling: 40 watts RMS/80 watts max *VCdia: 1-1/4" *Impedance: 4 ohms *Re: 3.6 ohms *Frequency range: 45-1,500 Hz *Fs: 45 Hz *SPL: 82 dB 2.83V/1m *Vas: .24 cu.ft. *Qms: 2.68 *Qes: .61 *Qts: .49 *Xmax 9.25mm *Dimensions: A: 6-1/8", B: 4-3/4", C: 3-1/8"
6.5-This one-of-a-kind 6-1/2" subwoofer has an impressive 11.5 mm of Xmax. A wide roll surround, raised flat spider, and large 1-1/2" 4-layer voice coil ensure impressive bass performance and high power handling. The vented pole and vented spider allow good airflow around the coil to improve heat dissipation and reduce compression. The compact neodymium motor structure saves valuable enclosure space while also allowing closer-than-normal placement to CRT's. The ultimate multimedia subwoofer driver!
Specifications: Power Handling: 50 watts RMS/100 watts max *VCdia: 1-1/2" *Impedance: 4 ohms *Re: 3.6 ohms *Frequency range: 35-800 Hz *Fs: 35 Hz *SPL: 85 dB 1W/1m *Vas: .51 cu.ft. *Qms: 2.81 *Qes: .32 *Qts: .32 *Xmax 11.5 mm *Dimensions: A: 7", B: 5-1/2", C: 3-5/8"
8in-The W8-740C is one of the highest excursion 8" subwoofers available on the market. It utilizes a heavy-duty paper cone, foam surround, and bumped back plate for maximum mechanical movement. The 2" 4-layer voice coil, vented pole piece, and heavy-duty aluminum voice coil former provide impressive power handling. Excellent for small-enclosure home or automotive subwoofers.
Specifications: Power Handling: 150 watts RMS/300 watts max *VCdia: 2" *Impedance: 4 ohms *Re: 3.2 ohms *Frequency range: 28-1,000 Hz *Fs: 28 Hz *SPL: 84 dB 2.83V/1m *Vas: .81 cu. ft. *Qms: 10.53 *Qes: .30 *Qts: .30 *Xmax: 12mm *Dimensions: A: 8-1/4", B: 7-1/4", C: 4-3/4"
8in-W8-1363SA -This one-of-a-kind subwoofer features outstanding Xmax and a powerful neodymium motor. A wide roll rubber surround, heavy-duty paper cone, flat spider, and large 4-layer voice coil give impressive bass and high power handling. Venting under the spider and through the pole reduce compression and maximumize heat dissipation. This is the ultimate small box 8" subwoofer!
Specifications: Power handling: 120 watts RMS/240 watts max *VCdia: 2" *Impedance: 4 ohms *Re: 3.20 ohms *Frequency range: 30-800 Hz *Fs: 30 Hz *SPL: 84 dB 1W/1m *Vas: .66 cu. ft. *Qms: 4.26 *Qes: .31 *Qts: .29 *Xmax: 12 mm *Dimensions: A: 8-5/8", B: 7-1/4", C: 4-3/4".
The amp- Small but mighty! This high performance amplifier module packs big-amp features into a compact chassis that is ideal for installation into cabinets that can't accommodate bulky old style amps. We made it small, but included everything that you need to connect the amp to your system and get maximum performance. Input/output connections are through your choice of either line level RCA connectors, or speaker level banana jacks. A stereo input signal is summed to mono and sent to the internal low pass crossover, which is selectable from 40 to 180 Hz, and the input gain sensitivity is fully adjustable as well. A phase reverse switch helps you to achieve the best acoustical match with the rest of your speakers, and an Auto On/Off switch keeps the amp standing by, waiting for an input signal to turn it on. A large surface area heatsink is combined with internal overload, thermal, and short circuit protection so that you can expect years of reliable operation.
Low distortion
Adjustable low pass crossover
High and low level inputs/outputs
Auto On/Off
Phase reversal switch.
75 watts RMS @ 8 ohms, 100 watts RMS @ 4 ohms
S/N Ratio: 90 dB (A-weighted)
Dimensions: 7-1/2" W x 8-11/16" H x 4-3/4" D
Which daytons? Almost all aftermarket speakers will be too much for an unprepared door. The Tang bands just have a better low end than most other speakers will in a IB application. I would stick with these and not the daytons, but if you insist i can order the daytons for you.
alteraudiousa
alteraudiousa
Concord, NC
outlawshovel
