D dbjunior 10+ year member CarAudio.com Elite 1,375 7 ma Dec 13, 2011 #1 What is an acceptable tolerance for daily use? The coil. I want to use will have. 075 inside and. 072 outside. This is total difference between pole and coil Id and top plate and coil od so centered should be half that all the way around Click to read more...
OP D dbjunior 10+ year member CarAudio.com Elite 1,375 7 ma Dec 13, 2011 Thread Starter #3 Anyone. I know Spl subs run a tighter gap than daily but what is the cutoff?
OP D dbjunior 10+ year member CarAudio.com Elite 1,375 7 ma Dec 13, 2011 Thread Starter #4 Should I ask on a different forum
06goat 10+ year member bumpin bluegrass 1,873 32 Michigan Dec 13, 2011 #5 Im gonna need the measurement down to 50 millionths for proper calculation
CHEMMINS 10+ year member CarAudio.com Veteran 4,277 115 Nevernever Land Dec 13, 2011 #6 Ask at DIYMA.
wenn_du_weinst 10+ year member CarAudio.com Veteran 4,726 163 ******* Dec 13, 2011 #7 I've ran a sub with tighter tolerances then that daily no problems
OP D dbjunior 10+ year member CarAudio.com Elite 1,375 7 ma Dec 14, 2011 Thread Starter #8 I've ran a sub with tighter tolerances then that daily no problems Click to expand... Thank you this was helpful. Time to buy coils.
wenn_du_weinst 10+ year member CarAudio.com Veteran 4,726 163 ******* Dec 14, 2011 #9 mine were at .06"
