Fusion EN-SW12ES
Single 4 ohm coil.
Got this in a trade, coil reads right around 4 ohms. Havn't tested her out yet to make sure she works. No reason why she shouldnt, but ill hook her up to my HT here in a bit.
20 bucks, plus shipping. She looks to BARLEY fit in a large flat rate box (would pack it the best i could, and should work fine)
so that would be 30 bucks shipped then.
# Max Power Rating (Watts): 400
# RMS Power Rating (Watts): 200
# Coil Height (Hvc): 20
# Compliance (Cms): 321.2
# Cone Area (Sd): 53.1
# D.C. Coil Resistance (Re): 3.6
# Electrical Q (Qes): 0.305
# Force Factor (Bl): 15.56
# Free Air Resonance (Fs): 24.14
# Frequency Response: 21Hz - 3kHz
# Impedance (Nominal): 4
# Linear Excurson (Xmax): 6
# Mechanical Excursion (mm): 23
# Mechanical Q (Qms): 2.78
# Moving Mass (Mms): 135.317
# Magnet Structure (Oz): 47
# Sensitivity (dB) (1W/1M): 89.6
# Total Loudspeaker Q (Qts): 0.275
# VAS (L): 128.6
# VAS (CuFt): 4.48
Single 4 ohm coil.
# VAS (L): 128.6
# VAS (CuFt): 4.48
