Nut Hair Trick
Pubes
I'm about to buy this amp to run in my setup. Up until now I've been using a KnuKonceptz distro block that has (2) 1/0 ins and (3) outputs for 1/0, 4, or 8. The block of course takes 3 mini ANL fuses which from what I understand, only go up to 150. External fusing for the AQ2200 is 200 amps so how should I do this? Buy an inline 200 amp fuse? If so, would I be able to run it off one of the 1/0 inputs even though the input wasnt really designed to be an output? I have a XS power D3400 up front and that's the only battery I have. Should I make another run of 1/0 to run to this amp? Suggestions are very much appreciated.
