Edward_Stryfe
Man of Many Pixels
So I am shopping around to figure out what to start myself off with, but I'm going to be doing this on my 1st car. I've got most of everything mapped out in regards to the amp and subwoofer I want to add. The amp I'm going to get for my sub will be
Rockford Fosgate Prime Class D 1-Channel Amplifier
http://a.co/0olAcOa
And the sub would be
Skar Audio EV-10 S2 10" Single 2Ohm 400watt Shallow Mount Car Subwoofer
http://a.co/5vZrraP
Since I'm on a budget I'm not going to immediately replace the factory speakers and amplify them yet. I'm gonna make the jump to add a sub first. But I'm not sure what my limits are on a battery. I'm also unsure about what's in store for me with the head unit, because it came built in with this service called onstar that is involved with the sound system and hooked up to rear view mirror. I'd like to for now just keep the factory head unit and make some sort of, "by any means necessary" connection to the sub. But that service has me questioning whether or not I can do that. I also haven't seen any guidelines to what a good range of fuse would be to use on varying setups.
So what I need help with is finding out if there's any extra business that has to be dealt with because of an onstar system, if you can hook a sub up to a factory head unit, and what a safe range would be for me to get a fuse to connect my battery and amp(s). I know that onstar has to do with security to a degree and when you have the service it does various things, but would it be especially difficult to do things with this head unit or even to remove it?
http://a.co/0olAcOa
http://a.co/5vZrraP
