I installed the goliath amp in my expedition yesterday and the amp does not work. The green light is on like its suppose to be when its working, but it will not send any power to the subwoofer. It should easily be able to pick up my solo x 18" as my kicker with only half the power; 2500rms was able to pick up this sub. This amp is suppose to be 5000rms.
I tried even putting some cheap kenwood 300rms subs and it would not pick them up either. I moved all the settings (gain, subsonic filter,phase shift, etc) with the stereo on and nothing would happen. I thought maybe something went wrong like I installed the rca cables in the wrong spot ( I tried moving through all of them, one of the speaker connections got loose inside the sub box, or one of the ground got loose or I blew a fuse. But when I reinstalled my kicker amp everything worked normal again.
I reinstalled the goliath amp again and the green light was on and the logo was lit but it wont pick up the sub no matter how much I tried messing with the settings or only using one channel then the second channel and running it bridged. I know that theres no power going to the spealer wires because when you unplug the positive or negative speaker wire on the terminal while the amp is on you'll see a spark, but nothing happens when I unplug the speaker wire from the speaker terminal, while the amp is on.
I hope you still have the warranty card, because I never received it. I cant return the amp to you untill I receive a refund and you cant refund my money untill I return the amp. Please contact me back, because if you dont then I will be filing a chargebcak with my credit card company and paypa.
Amp worked perfectly and I sold it as is, however, it is still under warranty. Fuc, I knew I should of just sold it to someone here.//content.invisioncic.com/y282845/emoticons/verymad.gif.3f39c5c2fd57527b671fad3efdfac756.gif
