Sold FT or FS Apline IVA-C801 motorized screen
Technical Specification
Satellite Radio Ready: No
Satellite Radio Ready: The receiver is compatible with optional tuners that will receive digital satellite radio broadcasts such as Sirius or XM Satellite Radio. The digital satellite service must be subscribed to separately.
RMS Power Output: 19.5x4 Watts
RMS: Root Mean Square is a formula that provides a reasonably accurate means of measuring and comparing continuous AC power. The use of this measure is preferred when matching system components, like amplifiers and receivers.
Preamp Voltage: 4 volts
Preamp Voltage: Refers to the strength of the pre-amp outputs. Generally, higher output voltages make it easier to get a cleaner and a more noise free signal delivered to amps and pre-amps.
Subwoofer Preamp Outputs: Yes
Preamp Output: Typically found on headunits, a preamp output provides low level, high quality audio signal for use with external amplifiers.
Maximum Power: 45x4 Watts
Maximum Power: The amount of power a speaker is estimated to handle during a brief high-intensity musical burst. Since this can vary with both frequency and amplitude, it is a much less accurate way to judge speaker durability and performance than RMS.
DIN: 1
DIN: Acronym for Deutsche Industrie Norm (Deutsches Institut fuer Normung), the German standardization body. A world reference standard for the mounting parameters of many common receivers ( Head ends) as well as other types of cables and equipment.
Changer Control: Yes
Changer Control: Receivers with changer controls operate same-brand/compatible CD or MD multi-disc changers.
CD Text: Yes
CD Text: The receiver can display disc and song title information contained on CD-Text encoded discs.
Built-in EQ: Yes
CD-R/CD-RW Compatible: Yes
Remote Control: Yes
Features
45W x 4 MOSFET Amplifier
6.5" Fully Motorized Monitor
Bass Engine®
"Digital Art" Spectrum Analyzer Display
Built-in CD Player
MaxTune SQ Tuner
Ai-NET Control Center
2 Auxiliary A/V Inputs
Dedicated Navigation Input
Auxiliary Monitor Control Output
Dual-In Circuit
Rotary Encoder Volume Knob
Navigation Audio Mix
Audio/Navigation Wireless Remote Control Included
Subwoofer Level Control
4 Volt PreOut
3 PreOuts
lastcall
lastcall
lastcall
League City, Tx
lastcall
