Sold FS: Zapco Ref750.2
Mirage_Man
Up for grabs is a Zapco powerhouse, the Ref750.2. I'm sure most of you are aware of the fact that this is one of the few amps made in the U.S. in the recent past. The one I am offering is in good condition overall with a couple small dings in the top edge of the heat sink, one a little bigger that was caused from being mounted on the back wall of a truck cab. As you can see in the pictures other than that it is in fantastic condition. I always try to take good pictures so you can see exactly what it is that you're getting. I hope these will suffice.
Here are the specs.
Stereo, 4 ohms: 2x175 Watts
Stereo, 2 ohms: 2x375 Watts
Bridged, 4 ohms: 1x750 Watts
T.H.D. + Noise:
S/N Ratio: >95dB
Slew Rate: >40V/uS
Damping Factor: >1000@4 ohms
Dimensions: 23"L x 7.5"W x 2"H
SymbiLink Balanced Inputs
RCA Unbalanced Inputs
2 ohm stereo stable
18 dB variable bass boost control
Dual variable electronic crossovers with x10 switch
Bridgeable
Three channel capable
High Current Bi-Polar output devices
Optically isolated MOSFET power supply
Aux output (Highpass/Lowpass or Fullrange)
Switch for use as stereo, single L ch. or R ch. bridge
L+R Sum Mono for use as a bass amp
Cooling fan allow any mounting position
Four layer PC board with heavy 2 oz copper
Surface mount technology w/1% resistors,
precision caps, and massive ground planes
I am asking $325 delivered anywhere in the continental U.S. Paypal is fine if you cover the fees. Paypal gift is also an option if you're OK with it.
Here are some pictures.
It was ever so gently brought to my attention that a pic including a piece of paper with my user-name and date hand written might make it easier to sell my amp. Thanks to the fine young gentleman that took time out of his busy day to inform me of my oversight. Here's a new pic I just took. My offer of $260 delivered still stands.
Mirage_Man
Mirage_Man
Florida
Mirage_Man
