up for sale is some stuff I have laying around
1) 2007 XXX component set, its NIB, never powered, only opened up the plastic to check everything and measure the mids. I was going to put them in my SUV, but they are too deep at 3" deep. everything else is packed up and new/. please note this is the newer non xbl2 version I think since I just bought them (not sure how to tell other than purchase dare?)
$300 shipped
2) Precision Power PPI PC650 anyway the amp is of course older, but work 10/10 has some cosmetic blemishes (small superficial scratches on the heatsink), and two of the mounting tabs are bent (can easily bend them back with some pliers if need be) but I know how cosmetics are a BIG deal
so its about a 6/10 and is priced accordingly well at least imo
the unit is 50x6, but the only caveat is that the rear two channels are crossover limited to 90hz even though they are class a/b channels ( They do run 100x2 @ 2 ohm though)
so this is basically a small 5 channel since subs these days are not as efficient as the one from this era
Ive ran this on two arc 12's in stereo so 50W rms @ 4 ohm (dual d2's) 12V and had no concerns with output in a 1.8 cu ft sealed enclosure, but I do think this would be awesome with two d4's wired to 2 ohm stereo
the front section is the same clean ppi 50x4 that most who know if one of the best ever made (well imo that is)
the amp will do 100x4 @ 2 ohm if you have 2 ohm mids (option orion hcca's, id's cxs series, and or the new series come in 2 ohm, also the RE XXX component set is also 2 ohm would be a great option imo)
lastly it will also do 200X3 bridged for those that have say three tens, or three efficient 12's, this is perfect imo
just not the best for super sub folks of course
210 shipped
I have the manual (very important when setting the crossovers, gains, and qbass controller usage if need be), I also have the Qbass controller (though its old, and missing the face cover, so its not in the best condition, but it does work though, and the original wire is mint and extremely long. all plugs are in perfect shape, nothing stripped. please disregard my mattress cover
ill have pics once I get home from work
my references
are two 750 gb 32mb cache hard drives, and a new DLP tv if you are local to norcal
$300 shipped
210 shipped
my references
all I need in tradeshttp://www.diymobileaudio.com/forum/showthread.php?t=21113http://www.diymobileaudio.com/forum/showthread.php?t=9628
http://www.diymobileaudio.com/forum/showthread.php?t=16217
http://www.diymobileaudio.com/forum/showthread.php?t=16079
http://www.diymobileaudio.com/forum/showthread.php?t=13043
http://www.diymobileaudio.com/forum/showthread.php?t=11721
http://www.diymobileaudio.com/forum/showthread.php?t=8563
http://www.diymobileaudio.com/forum/showthread.php?t=7376
http://www.diymobileaudio.com/forum/showthread.php?t=6358
http://www.diymobileaudio.com/forum/showthread.php?t=3152
http://www.diymobileaudio.com/forum/showthread.php?t=21982
http://www.diymobileaudio.com/forum/showthread.php?t=25734
http://www.diymobileaudio.com/forum/showthread.php?t=27944
http://www.diymobileaudio.com/forum/showthread.php?t=24983
http://www.caraudio.com/forum/showthread.php?t=170338
http://www.caraudio.com/forum/showthread.php?t=160744
http://www.caraudio.com/forum/showthread.php?t=104632
