Basically, I bought this and used it all of two weeks to push some comps(although it is a sub amp) This amp gives out clean power, I can honestly say, and you can't ask for much more out of the amp. 150x2 at 4, 225x2 at 2, and 450x1 at 4 bridged are the main specs on this amp, everything else is below. Make an offer, I'm asking 100 shipped on it, but that's (somewhat) flexible. Not really looking at trades right now, unless I can add cash for a nice 4 chan amp. All offers that are reasonable are welcomed. Amp is in decent condition, as it has some scratches, but works perfect. All of the information below was listed from CarDomain.com's page for purchasing this product, which by the way is $170.00 plus shipping..
Features:
MMT Regulated Power Supply
Mosfet Output Transistors
Low-Pass Crossover
24 dB LP Crossover Slopes
Line Input / Line Output Crossover Switch
Variable Bass Boost at 40 Hz
Preamp and High-Level Inputs
Preamp Outputs
Intense Blue Power Indicator LEDs
Terminal Block Style Power & Speaker Connectors
Tri-Mode Capable
Protection and Turn-On Delay Circuitry
Specs :
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 150W x 2 @ 12.9V
THD at 4-Ohm RMS Power:
Bridged RMS Power @ 4 Ohms: 450W x 1 @ 12.9V
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 10-30,000 Hz
Signal to Noise Ratio: 105 dB
Fuse Rating: 2 x 30 amps
Actual Pic -
Features:
Low-Pass Crossover
Preamp Outputs
Tri-Mode Capable
Specs :
Preamp Outputs: Yes
Actual Pic -
