FS/TX Plasma Cutter, Mig Welder, and Torch setup
frkkevin
All items are new. Best way to contact is call/text 817-776-1205
$900 obo
DRAG-GUN® PLUS with Humidifier 1/2" Cut 1-3835-1F 230v
This is a portable unit with a built in air compressor so no need for shop air.
Includes:
* * Power Supply * Torch and Leads * Input Power Cable and Plug * Work Cable and Clamp * 3 Tips * 2 Electrodes * Operators Manual
* Quick Specifications Output Current 15-35 Amps, Continuously Variable Input Power 230V (± 10%), Single Phase, 50/60 Hz., Ieff: 18 Amps Duty Cycle 35% @ 35 Amps Weight 76 lbs. (34.5 kg)
$320 obo
Victor Thermadyne VCT 1444-0328 Mig-Welder Fp165-230V with cart
(spool of wire included.. can run gas or gasless)
* Maximum Output: 165 Amp
* Input voltage: 230V
* Maximum DC Volts: 30
* Duty Cycle (@ 104 degrees F): 20% @ 130 Amp 30V
* Max. Steel Thickness: 3/8"
* MIG Wire Feed Rolls: .023-.030/.035"
* Processes: MIG, Fluxcore
$200 obo
Portable torch setup with tanks.
Firepower 0384-0990 Portable Tote
* WH260C Series Torch handle with built-in reverse flowcheck valves Flashback Arrestors
* 150 Series Cutting attachment
* 150 Series Oxygen/Acetylene regulators
* goggles/shade #5 and striker
* Specifications:
* Dualine hose: 3/16” x 12.5’
* Weight: 36 LBS.
* 2 Welding nozzle welds to 1/8”
* 0 Cutting tip cuts to 1/2”
* 10 cu. ft. “MC” acetylene cylinder and 20 cu. ft. “R”oxygen cylinder (shipped empty)
frkkevin
frkkevin
US
kmanian
