Sold FS:/Trade: xx colossus
Dual monoblock, class D design
2 x 600W @ 4 ohms
2 x 1100W @ 2 ohms
2 x 1600W @ 1 ohm
1 x 2000W @ 4 ohms bridge
1 x 3200W @ 2 ohms bridge
Damping Factor: 400
S/N Ratio: 98dB
THD + Noise:
Dimensions: 41" x 11.2" x 2.6" (104cm x 28.5cm x 6.6cm)
from roe's amp guts section..
it's rated at 12.2volts also.
I have a pair of phoenix gold x600.1s birthsheeted 879rms on one, the other I don't have the box and paper work for but they all birthsheet out around the same. 800+ from 1-4ohm if you bypass the xeload they'll do more. I'd only do that at 2ohms or burps possibly lower. if the pending trade falls through and your intrested lmk, I miss my old genXX a little sloppy but lots of power I could use to run a single load //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif . I have power, but on two loads //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif don't like running one amp per coil, one of my subs is sitting with a single coil blown from the last time I attempted that lol.
JL Audio
ThugStep
JL Audio
KY
RollinGTO
