FS: three great 10" subs (alumapro, JL, Arc Audio)
tyroneshoes
886
NJ
These are the woofers that were either too deep or just could not fit in my stealthbox. All are under 5.5 inches in depth. All great subs with the Alumapro being one of the most efficient and transparent SQ subs I ever ran.
Alumapro MX 10" dvc 6 ohm BNIB
-perfect for those 5 channels that you dont want to run at 2 ohms but not powerful enough at 4 (think boston) and any app.
And explaining the MX series from the alumapro designer:
Originally Posted a few years back when I made a thread on these subs.
As noted in several of the links in this thread, the AlchemyMX is very adept at blending in with the mids and without drawing attention to itself as a subwoofer. Please allow me to offer a few of the design criteria for the AlchemyMX:
This model sub is foremost designed for SQ. Unlike the RX version, which is optimized for SPL applications in the 45-80 hz range, the AlchemyMX features a very low-mass pistonic cone and linear suspension. When installed in a modestly sized enclosure of 1.0-1.1 Ft3, the anechoic F3 will be about 50 hz which closely complements the typical automotive environment (transfer function). In most applications, the summed response will be relatively flat from 20-80 hz.
The low moving mass is good for efficiency, and the AlchemyMX is among the most efficient subwoofers available---for example, when Car Audio compared it to the eclipse Titanium Sub (made by TC Sound), the AlchemyMX only needed 330 watts to match the output of the Eclipse running on 1000 watts. But there's more than efficiency, the low mass also yields fast transients. The AlchemyMX sounds more like a big midrange than a wooly subwoofer. In Japan, where the AlchemyMX is considered the Rolex of the industry, they appreciate the continuity of the tone. That is the ability for all the notes to have the same characteristic sound---picture an acoustic bass where all the notes have the same natural steely tone. A massive subwoofer cone will not accurately track the nuances of the tone and will smear the sound resulting in an unnatural thickening of the lowest bass notes. The alchemyMX should retain its overall tone throughout its usable range, and instruments sound more like the real thing.
The suspension is very linear (for SQ) and depends to a great extend on the air stiffness of a sealed box to prevent over-excursion. As noted by one member, the box is purposely recommended slightly small to improve power capacity. This is very common in the industry , and does compromise the bass extension, but it also prevents bottoming of the cone. 1.0-1.1 Ft3 is not overly small for the MX12, but a larger box up to about 1.4 Ft3 will yield deeper bass, assuming you do not grossly overpower it. The bigger box lowers the resonance and therefore the F3. Other subwoofers achieve deeper bass in similarly small enclosures by increasing the mass of the cone assembly. This lowers the resonance at the expense of efficiency, but more important, it smears the notes. As an experiment, I added significant mass to the Alchemy cone and adjusted the BL (motor strength) to compensate the Qtc. While this certainly made the bass go deeper, the tone became thicker and less articulate. Ultimately, it sounded more natural to use the unweighted cone and simply EQ the bass electronically.
You see, that is one of the virtues of a high-efficiency driver---you need less amplifier power to drive it, so you have more left over for EQ. Most of the time, the amplifier is loafing and causing less strain on your alternator. Only the lowest notes, if EQ'd, use more power. So the overall power consumption is higher AND you get the cleaner tone of the low-mass cone.
Matthew
Alumapro, Inc
160 shipped to US
BTW, The 6 dvc versions are no longer available online and custom order only.
more to come
Arc Audio 10" D4 - seems slightly used but in great shape. Cone is perfect and looks new.
Originally wanted to install this sub. Still would be my top choice but just a tad too deep.
Great sub. I ended up with a idq v2 in my stealth box because it was shallower but you can never go wrong with an ARC or IDQ. They never sound bad. RIP ID.
$145 shipped
Then I have the JL w1v2 10 svc 4 ohm with JL grill that came with my stealth box.
Used for 3 days. Basically new. This sub surprised me and sound pretty **** good. I almost just said forget it, this sub sounds good enough as is. But you how that goes. Def one of the top budget subs. 4.5" deep
The grill itself is expensive as is as jl only uses magical pixie dust.
$90 shipped.
I have lots of other stuff for sale as well so check my other auctions to save on shipping and price cuts for multiple items.
Not for me apparently. Ive been selling here for a long time and have 20+ interactions.
Here's some feedback
DIYMA.com
I post on DIYMA usually
As if the distinct bamboo floors in all my fs posts was not enough.
Here ya go you silly guy
tyroneshoes
tyroneshoes
NJ
Bettr n' Revrse
