Sold FS/T: Zapco REF750.2
emilimo701
i recently bought this amp:
pictures here:
http://www.caraudio.com/forum/car-audio-classifieds/482057-fs-zapco-ref750-2-a.html
i can't stand the cooling fan. it's not really that loud; i just have OCD or something, and i have a wagon. in a trunk it would probably be completely inaudible.
i'd like to trade for a class A/B two channel, preferably rated >125w @ 4Ω, but would also consider selling it.
i dont have a camera for username/date, but just check my feedback i bought it off Mirage_Man
Large Mono Amp?!?!? You dont realize what your sitting on do you? That amp is amazing sq. Ruffly 900w@4ohms ,12.4v. And it can be modded to run down to 1 ohm mono but the current draw is stupid. somewhere like 300a, but produces about 2k of CLEAN, ultra low distortion, class ab power. Not the crappy class D high switched amps you see all the time. I currently run one @3ohms mono for about 1k to a tc sounds custom built lms. It will easily push that sub past its xmech if i wanted it to.
So if your interested in giving it away at that price, ill offer up a custom built TC sounds 3hp for it. I can build to 10,12, or 15. Built around the specs you need.
Large Mono Amp?!?!? You dont realize what your sitting on do you? That amp is amazing sq. Ruffly 900w@4ohms ,12.4v. And it can be modded to run down to 1 ohm mono but the current draw is stupid. somewhere like 300a, but produces about 2k of CLEAN, ultra low distortion, class ab power. Not the crappy class D high switched amps you see all the time. I currently run one @3ohms mono for about 1k to a tc sounds custom built lms. It will easily push that sub past its xmech if i wanted it to.So if your interested in giving it away at that price, ill offer up a custom built TC sounds 3hp for it. I can build to 10,12, or 15. Built around the specs you need.
I have a dual 2 ohm Axis. So i'm looking for about 2200-3000 watts at 1 ohm. But like I said, I hate to cavil but the reason for selling is the fan :-/
Dude, pop the cover off and disconnect the fan. Should take like 5 minutes.
Lol. Right on!
What size axis do you have.
Dude you have about one of the best sq amps available to mainstream. If your unhappy with the performance then your either just trying to be loud, or something isnt setup correctly.
lol. wow i feel dumb now. i'll do this tomorrow during the day time hopefully it works out. i'm assuming the amp's not dependent on the fan for cooling. i know amps get less efficient as your drop the resistance, but would it be better to run 2-ohm speakers?
Lol. Right on!What size axis do you have.
well, that is one of the goals. but there aren't that many amps out there that put >350 watts x2, considering budget, features, and availability
emilimo701
emilimo701
Boston, MA
emilimo701
