FS/T: Verizon HTC Incredible
whitedragon551
Moderator
Clean ESN
I ran it rooted with MIUI. I have returned it completely back to stock and unrooted. I can root it for you if you would like. You will have to request this.
Its been used for the last 2 years. Has a couple scratches in the screen. You cant see them when the phone is in use. Has a few knicks on the outer edge near the charger. The plastic piece over the camera is also cracked. This is a cheap $5 part that I just never got around to replacing. It just pops right off.
I also have a Zagg screen protector that I bought. I originally had it on, but the corners started peeling up so I just took it off. I can get it replaced for $5 and have it shipped to you.
Will come with charger, original 1300mah battery, HTC Innovation 1500mah battery, original box, white glossy HTC back, and white Seidio Innocase.
$75
$80 if you want the Zagg screen protector replaced and shipped directly to you from Zagg.
Will consider trades of equal or less value + cash on your end. Offer up what you have via PM.
Via Flat rate USPS. Any other method will be at your choice and you will pay the difference in shipping costs.
whitedragon551
Moderator
whitedragon551
IL
whitedragon551
