Sold FS/T=Orion HCCA-D1200 AMP
FASTIMES
Still in Dis B!tch.....
I have this Orion D1200 that's about a month old. Mechanically 10/10. Appearance 9/10 because of small scratch under the word "high" as seen in pics.
  • 1200W Class D Mono Amplifier
  • RMS @ 4 Ohm: 1 x 250
  • RMS @ 2 Ohm: 1 x 400
  • RMS @ 1 Ohm: 1 x 600
  • Variable low-pass 30Hz to 250Hz
  • variable high-pass with INTELLi Q 20Hz to 150Hz
  • 10dB of boost with INTELLi Q
  • Remote gain capable
  • Selectable AUX out
  • Fuse size: (2) 40 ATC
  • Dimentions: 11" x 10.2" x 2.4"
  • Power Rating: 250 Watts RMS x 1 at 4 ohms
  • Signal to Noise Ratio: -59dBA (reference 1 watt into 4 ohms)
  • Additional Power Output: 600 Watts RMS at 1 ohm
  • Massive loosely-regulated MOSFET power supply
  • IntelliQ Bass Optimization Circuit and Remote Gain Control
  • Heavy Gauge Direct-wire High Current Power and Speaker Terminals
  • 18dB/octave Low-pass Filter
HCCAD1200 - Orion HCCA D1200 1 Ch 1200 Watt Amplifier
$150 or open for trades!
FASTIMES
FASTIMES
(909)...SoCal
FASTIMES
