FS: Sprinter S12V285F Batts
Boomsday
(20) Sprinter S12V285F 83ah
Bought these with intentions of mounting them under my truck. But in Meca that would put me in a different class and I dont want to do that.
Good for about 2-2.5k each.
$110shipped ea
I was looking at one for under the hood and was just curious as to how much stronger it was as a starter than what I currently have. If it's significant enough then I'll get one if he still has them in a couple weeks.
Id say its quite a bit more powerful than most under the hood batts ..most range in the 50-60ah range ...check ur specs against it and compare ..also check size vs. What u have to make sure it will fit
Couldn't find much specs that I could compare with these batteries. And I figured out a way I could fit a Deka G31 with a little bit of wood, screws, bolts and a latch haha
Cca means nothing in car audio application . Ah and rc is what ur after
CCA means something in a car audio application. AH really dont mean much in a car audio application. Just really depends on what you are after. If you are burping CCA/CA means a whole lot. If you are demoing then you still want to look at CCA/CA just add more...
Ive just never heard anyone bring up cca/ca numbers when talking abt car audio application ..ever...just a rule of thumb of 55ah per 1000rms.never a cca rating per certain rms ..
Boomsday
Boomsday
My House
Bassman999
