The picture is an anomaly from the angle of the shot, the camera settings, and the lighting. It's not crooked, although it sure does look funny.
RL-i motor, prototype softparts.
$165 SHIPPED
paypal: blake.carroll@gmail.com
Paper boobcone, you say?! In that case, you are indeed running a prototype
driver, only two of which I ever sold to anyone.
The coil diameter on the protos is 2" (same as our production model), but it
is configured for single 6 ohm. Power-wise, it should not need more than
300 watts RMS for optimal performance, though you could use a 500 watt power
source so long as you are a responsible user and aren't crankin' the gain/EQ
full tilt.
The T/S param's on the units you have are as follows:
Qts - 0.405
Qes - 0.442
Qms - 4.778
Fs - 34.289 Hz
Re - 5.25 Ohm
Ls - 12.16mH
Lp - 4.053 mH
Rp - 25.46 Ohm
Sd - 0.020 m^2
Vas - 5.031 L
Mms - 214.1 g
Cms - 100.6 m/N
Bl - 23.39 T*m
Sensitivity - 78.44 dB
2nd generation RL-i's utilize a black annodized spun aluminum cone similar
to the rest of our RL-i's and RL-p's, peep the following images:
http://www.soundsplinter.com/images/drivers/RL-i8_top.jpg
http://www.soundsplinter.com/images/drivers/RL-i8_profile.jpg
http://www.soundsplinter.com/images/drivers/RL-i8_BackAngle.jpg
As you can see from the first image above, the logo takes up a good amount
of the cone space (since it is the same physical logo size we use on the
10's, 12's, and 15's). Therefore, gettin' a signiture on there may get a
little messy since the cone has a steeper concave surface and I'd have to
work around the logo. If you'd like me to do it, I will.. but I just think
it may get a little busy and won't look as nice as it would on the larger
drivers.
~mike
