FS: Sony CDX-GT700HD
FLboy4x4
Sony CDX-GT700HD
I had this headunit in my truck for about a month and decided to change to an in dash screen
WMA Playback: Yes
Satellite Radio Ready: Optional
RMS Power Output: 4x18 Watts
Remote Control: Yes
Preamp Voltage: 2 volts
Subwoofer Preamp Outputs: Yes
MP3 playback: Yes
Maximum Power: 4x52 Watts
HD Radio: Optional
DIN: 1
Detachable Face: Yes
Changer Control: Yes
CD-R/CD-RW Compatible: Yes
CD Text: Yes
Built-in EQ: Yes
Bluetooth: Optional
Aux input: Yes
Front USB Input: Yes
Color: Dark Titanium / Black
Disc Capacity: 1
CD Text Display: CD and MP3 / WMA data displayed
Illumination: Switchable: Blue / Green
On-Screen Clock: 12H
CD: Yes (CD-R/RW)
12V Trigger Output(s): Power antenna Amplifier turn on
Antenna Terminal(s): Aerial Input Terminal
Audio In: Front Aux input with variable level: -8dB ~ +18dB Front USB input Sony Bus audio/controll terminal
Digital Audio Input(s): -Ability to use all forms of USB devices may vary as not all devices are compatible. This unit can be connected to the following iPods. Update your iPod to the latest software before you use it. -iPod Nano 1st generation* -iPod Nano 2nd generation (aluminum) -iPod Nano 3rd generation (video) -iPod 5th generation (video)* -iPod Classic -iPod Touch -iPhone When you connect iPod Nano1st generation or iPod 5th generation, Passenger Control is not available. -This unit is compliant with MSC (Mass Storage Class) and MTP (Media Transfer Protocol) type USB devices compliant with the USB standard. -This unit cannot recognize USB devices via a USB hub. If you have any questions or problems concerning your unit that are not covered in this manual, consult your nearest Sony dealer.
Infrared Port: Wireless remote
RCA Audio Output(s): Front, Rear, and Subwoofer RCA pre-amp outputs
Remote Jack: Optional wired remote terminal
USB Port(s): Front USB - Full Speed
Max power output: 52 watts x 4 at 4 ohms
Speaker Impedance: 4-8 Ohms
Band: AM / FM
CD Playback: CD, CD-R / CD-RW (MP3/WMAfiles)
Digital-to-Analog Converter: 24bit
Frequency Response: CD: 10-20,000 Hz
Preout Impedance: 220 ohms
Preout Voltage: 2 volt
Signal-to-Noise Ratio (dB): CD: 120 dB
Station Preset(s): 18 FM / 12 AM
Tone Control(s): Low +/- 10 dB at 60 Hz Mid +/- 10 dB at 1 kHz High +/- 10dB at 10 kHz
Tuner Frequency Range: FM:Tuner Frequency Range(MHz): 87.5-107.9, AM:Tuner Frequency Range(kHz): 530-1710
Tuner Type: SSIR-EXA
Volume Control: Tel/Nav Attenuation Circuitry
Wow and Flutter: Below measurable limit
FM Usable Sensitivity: 8 dBf
Frequency Response: FM: 20-15,000 Hz (conventional broadcast) FM: 20-20,000 Kz (HD Radio broadcast)
S/N Ratio: 71 dB (mono), 80dB (HD Radio broadcast)
Selectivity: 75 dB at 400 kHz
Stereo Separation: 50 dB at 1 KHz (Conventional broadcast) 80 dB at 1 KHz (HD Radio broadcast)
Current Drain: 3 - 5 amps
Input Power: 12 V DC car battery (negative ground (earth))
Input Voltage: 12 V DC car battery (negative ground)
Output Power: 52W x4 High Power - 17 watts per channel minimum continuous average power into 4 Ohms
I'm asking $140.00 Shipped
Shipping included I will ship usps with tracking and I will give you the tracking number as soon as it ships
FLboy4x4
FLboy4x4
Lehigh Acres, FL
FLboy4x4
