FS: Rockford Power BD1000.1
michaellane
BD1000.1 and a 800.4
9.5 out of 10 for both amps. amps work great and looks awesome. this is a old school beast of a amp
$250.00 plus the ride a piece. at the moment no trades but maybe a partial trade for a budget 1500rms@1ohm...something like a elemental nine.1 or maybe some older eclipse amps...but cash is first i guess
On the buyer
also have a blown bd1000.1 in the same shape cosmetic wise.
500 watts RMS x 1 at 4 ohms
1000 watts RMS x 1 at 2 ohms
Class bd technology
requires 4-gauge power and ground leads and a 100-amp fuse and fuse holder — wiring and hardware not included with amplifier
selectable 50-250 Hz variable low-pass crossover, 24 dB/octave
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ noise-killing differential inputs eliminate 80% of ground loop noise
preamp outputs for easy connection to a second amplifier
bd Sync — allows you to bridge together two separate Rockford Fosgate Class bd amps (with an optional cable) to power one woofer
subsonic filter removes frequencies below 20 Hz for increased efficiency
13-1/8"W x 2-3/8"H x 9-7/8"D
michaellane
michaellane
tx
michaellane
