Sold FS: Rockford POWER 1501db Older Model - $350 OBO
sundownz
Pro Seller
Supporting Vendor
This amp has been tested to work properly here on my test bench. There is NO further warranty expressed or implied beyond that it will work when you receive it.
You have FIVE DAYS to test it once receiving it. If you do not have the capability to test within five days DO NOT BUY IT. No exceptions. If you don't agree to these terms do not even ask about buying this amp.
Unusually good condition 1501bd amplifier. Has end caps AND remote.
ONE speaker screw is getting a little stripped but still tightened down on the test bench. Just be careful with it and it will not present a problem.
that isn't the right remote for it? i though the grind style amps all took the barrel style RF remotes. the square ones could **** it up.
Being that the guy I got it from owns six identical amps and is the original owner and I tested the remote to work on the bench I think it is right //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
why would that **** it up? no. Dont see these in such good shape anymore.
the newer square ones r 8 pin and the older barrel style are 6 and even if u jimmied a 6 in into the 8 its all internally different anyhow, right down to the Potentiometer rating the old one are 5K i beleive and the new ones have a significantly greater value.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
