I have for sale two Rockford Fosgate Amplifiers. One amplifier is the P300-1 model and the other amplifier is the P300-2 model. These are the NEWEST/LATEST Punch models with the black brushed heatsink. These were bought brand new in April 2009. I am asking $150 obo EACH or $280 obo for the pair. These amps are significantly UNDERRATED. According to the birthsheets, the P300-1 puts out over 425 watts in a 2ohm load and the P300-2 puts out over 380 watts in a 2ohm load. They sound extremely clean...no hissing, turn on pop or background noise like you would get with an inferior/cheap amp. Both of these are more than enough to run an entire system. I had these running a system consisting of 2 6.5 Woofers 2 tweeters & a 10 inch subwoofer and these amps were more than sufficient and put out VERY CLEAN sound.
These are the current models. I have used them for about 2 and a half months. I have ALL hardware/documents/manuals/birthsheets/boxes. NO SCRATCHES/DENTS/SCUFFS...they are like new and cosmetically I would say they are a 10 out of 10. These were bought brand new from an Authorized Rockford Dealer and I have been the sole owner...these are not refurbished. They work flawlessly & I have the pics/videos to prove it. They have been adult owned and well taken care of. SERIOUS BUYERS ONLY. These are a steal at this price...you will not find these locally anywhere close to this price. I need to sell as life changes demand I come up with some extra cash. I WILL TAKE ANY REASONABLE OFFERS....ALSO THROW IN A PEQ KNOB IF YOU BUY BOTH.
ALSO GOT A ROCKFORD FOSGATE Punch P3 Shallow mount sub for sale. Also like ALMOST NEW. Contact me if interested.
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=6&family_id=19&item_id=108231&locale=en_US&p_status=
http://www.rockfordfosgate.com/products/product_details.asp?cat_id=2&series_id=6&family_id=20&item_id=111370&locale=en_US&p_status=
SPECS FOR THE PUNCH P300-2
Number of Channels 2
Rated Power
continuous power 75W x 2 @ 4-Ohms RMS
150W x 2 @ 2-Ohms RMS
300W x 1 @ 4-Ohms bridged RMS
Total Power
total sum of 'rated power' 300 Watts
Dynamic Power
powercube measurement (info) 114 Watts x 1 @ 4-Ohms 0° Res
184 Watts x 1 @ 2-Ohms 0° Res
Bridgeable Yes
Efficiency (average) 66% @ 4-Ohm
60% @ 2-Ohm
Crossover Controls High-Pass (HP): 50Hz-500Hz 12dB/octave Butterworth
Low-Pass (LP): 50-500Hz 12dB/octave Butterworth
Tone Controls Punch EQ2 Bass: 0dB to +18dB @ 45Hz and/or
Punch EQ2 Treble: 0dB to +12dB @ 12kHz
Function depends upon LP/AP/HP switch position
Signal Input Low level: 1 RCA pair
Signal Output n/a
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional PEQ Remote Punch EQ
(overrides built-in Punch EQ2)
Visual Indicators Power
Thermal
Protect
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 1.0dB
Shipping Weight 6.34 Lbs.
(2.87 Kg.)
Dimensions (HxWxL) 2.25 x 7.625 x 9.0 (in)
5.71 x 19.37 x 22.80 (cm)
SPECS FOR THE PUNCH P300-1
Number of Channels 1
Rated Power
continuous power 150W x 1 @ 4-Ohms RMS
300W x 1 @ 2-Ohms RMS
Total Power
Dynamic Power
powercube measurement (info) 240 Watts x 1 @ 4-Ohms 0° Res
404 Watts x 1 @ 2-Ohms 0° Res
Bridgeable No
Efficiency (average) 69% @ 4-Ohm
65% @ 2-Ohm
Front Punch EQ2 Treble: 0dB to +12dB @ 12kHz
Signal Output n/a
Cooling Convection
Thermal
Protect
(2.87 Kg.)
Rated Power
Total Power
Dynamic Power
Bridgeable Yes
60% @ 2-Ohm
Signal Output n/a
Cooling Convection
Thermal
Protect
(2.87 Kg.)
Rated Power
Total Power
Dynamic Power
Bridgeable No
65% @ 2-Ohm
Signal Output n/a
Cooling Convection
Thermal
Protect
(2.87 Kg.)
