FS: Rockford Fosgate 3sixty.2 w/Treo 750
greywone13
USED condition: Rockford Fosgate 3sixty.2 w/Treo 750 and USB cord for phone. I do not have the remote or remote cord. Not lookin for any trades.
8/10 cosmetically, has some small scratches and one of the feet is broken. (see picture)
Rockford Fosgate Advanced Interactive Signal Processor
Just when you thought that your aftermarket sound system couldn’t get any better, the Rockford Fosgate 3SIXTY.2 comes along. Enabling advanced signal processing that is both interactive and intuitive, this sound processor delivers unprecedented control and flexibility to aftermarket and OEM sound systems.
With the 3SIXTY.2 from Rockford Fosgate, up to 153 bands of equalization and manipulation are enabled for complete audio control. You are able to wirelessly make all the adjustments wirelessly with a Bluetooth connection. After installing the software onto your laptop or handheld device (running Windows CE or Palm), you will be able to wirelessly tune and hone the sound of your vehicle. The equalization allows for the adjustment of 31 bands in the front speakers, 27 bands in the rear speakers, 27 bands for a center speaker, and 10 bands for a subwoofer.
Installation on the 3SIXTY.2 is universal and compatible with all aftermarket and factory stereos. Simply connect the high-level speaker inputs and/or the low-level RCA inputs and you will be ready to start customizing your systems audio. The software allows for a visual confirmation of the audio frequencies so you can more accurately enhance the audio quality of the system. The 3SIXTY.2 even allows for an automatic equalization of factory sound. The Rockford Fosgate 3SIXTY.2 is the ultimate in audiophile grade sound customization for those that require the most out of there system.
Interactive signal processor lets you expand and fine-tune any car audio system
Handheld Palm® 5.0 or higher device with Bluetooth® capability required for making system adjustments
Six high-level speaker inputs (front, rear, subwoofer, and center channel)
Six low-level preamp inputs (front, rear, subwoofer, and center channel)
Six 5-volt preamp outputs (front, rear, subwoofer, and center channel)
153 adjustable bands of equalization
31 bands each for the front right and left speakers
27 bands each for the rear right and left speakers
27 bands for the center channel
10 bands for the subwoofer
Time alignment
Auxiliary audio input with 31-band equalizer
Low-pass, high-pass, and bandpass crossovers for the front, rear, and center channels (62 steps between 50 Hz and 10kHz, 12 or 24 dB/octave)
Subsonic filter for the subwoofer (12 or 24 dB/octave)
Sound settings memory lets you save your EQ settings on your Palm device
Automatic equalization of factory sound
Auto sum capability compensates for deficiencies in factory sound
On-board digital signal processor
Dash-mountable volume knob and source selector
Displays before-and-after comparison of sound equalization
7-1/4"W x 1-3/4"H x 4-1/4"D
$250 + shipping
greywone13
greywone13
Huntington Beach, CA
zuppy
