Used for about 6 months bridged to a single 12". Never had any problems. Comes with replacement set-screws , bass knob/wire , endcaps/screws and maybe some power wire to go with it if i have some laying around.
Specs:
87.5 watts RMS x 2 at 4 ohms
175 watts RMS x 2 at 2 ohms
350 watts RMS x 1 at 4 ohms in bridged mode
stereo or bridged mono output
Tri-way capable (Tri-Way Crossover required)
MOSFET power supply and output devices
50-250 Hz high-pass/low-pass crossovers, 24 dB/octave slopes
MEHSA mounting technology increases the heat transfer from the MOSFET output devices to the heat sink, for higher power output, lower operating temperatures, and greater reliability
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
*****•ana circuitry keeps preamp voltages low and signal paths simple for outstanding audio quality
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
wired remote control included for fingertip control of Punch Bass (for 0-18 dB of bass boost at 45 Hz)
preamp-level (RCA) inputs
preamp (RCA) outputs (provides signal for a second amplifier)
10-gauge power and ground cables recommended — wiring and hardware not included with amplifier
dimensions: 11-3/8"W (8-15/16" without endcaps) x 2-7/16"H x 9-7/8"D
90 Shipped OBO.
Need it gone before i decide to keep it again. Pics will come later tonight.
Specs:
90 Shipped OBO.
