Sold FS: Rockford Fosgate 25 to Life Power 1000 Chrome 5 Chan beast
alex5857
1. Product:
3. Description/Condition:
Ran the amp for 6 months without a hitch, not a single shutdown or anything. I have never pushed the amp hard at all. It has a coupe scratches on the chrome and one of the screws for the speaker input is stripped, it can still come out if you use a flathead but i just attached a wire so i wouldn't strip it more than it already was. other than that the amp works 100%
This thing is a beast and will surely put out more than rated.
Physical: 7/10
Mechanical: 10/10
4. Price: : 420Shipped OBO
5. Pictures:
Did the best i could to get a picture of the one speaker outlet
A quick pic of it working
2. Specs:
Rockford Website
Number of Channels 5 Rated Power
continuous power Front/Rear Channels
50W x 4 @ 4-Ohms RMS
100W x 4 @ 2-Ohms RMS
150W x 4 @ 1-Ohm RMS
200W x 2 @ 4-Ohms Bridged Mono
300 x 2W @ 2-Ohms Bridged Mono Sub Channel
300W x 1 @ 4-Ohms RMS
600W x 1 @ 2-Ohms RMS
800W x 1 @ 1-Ohm RMS
Total Power
total sum of 'rated power' 1400 Watts Dynamic Power
powercube measurement (info) Front Channels
111 Watts x 2 @ 4-Ohms 0° Res
185 Watts x 2 @ 2-Ohms 0° Res
267 Watts x 2 @ 1-Ohm 0° Res
Rear Channels
187 Watts x 2 @ 2-Ohms 0° Res
272 Watts x 2 @ 1-Ohm 0° Res
Sub Channel
832 Watts x 1 @ 1-Ohm PVC Bridgeable Yes (front/rear) Crossover Controls Front Channels
High-Pass (HP): 40-400Hz 12db or 24db/Octave Linkwitz-Riley
Low-Pass (LP): 40-400Hz 12db or 24db/Octave Linkwitz-Riley
10x crossover switch Rear Channels
Sub Channel
Low-Pass (LP): 32-250Hz 24db/Octave Linkwitz-Riley
Infrasonic filter: 28Hz fixed
Tone Controls Bass: 0dB to +18dB @ 35-75Hz (sub channel) Signal Input Low level: 3 RCA pair
Signal Input Switch: 2/4/5 Signal Output n/a Power Input Connector Block Power Wire Gauge 1/0 AWG Speaker Output Connector Screw terminal barrier strip Speaker Wire Gauge 12 AWG Heat Sink Type Cast aluminum Cooling Fan Cooled Remote Controls ParaPunch Bass EQ (included with cable) Visual Indicators Power On
Thermal
Output Short Circuit
Fan On 3 Stage Termal
Low B+ Voltage (below 11VDC)
5-channel Level Monitors Circuit Topology Class Front/Rear Channels
Class A/B Sub Channel
Class BD
Frequency Response Front/Rear Channels
20Hz to 20kHz +/- 0.5 dB Sub Channel
20Hz to 250Hz +/- 3dB
Shipping Weight 13 Lbs.
(5.9 Kg.) Dimensions (HxWxL) 2.6 x 12.8 x 23 (in)
6.6 x 32.51 x 58.42 (cm)
alex sell me this in payments or ill show everyone those pix we took in vegas
//content.invisioncic.com/y282845/emoticons/sneaky.gif.7189749b3a3f769e8815b47e8ae87f88.gif
I think we can work something out, PM me.
and sorry i have no birthsheet //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
alex5857
alex5857
California
tlutzbboy@yahoo
