Sold fs: Rockford Fosgate 1500BD.
J31Rob
CarTune Netwerk
- Missing the RF emblem in the middle & the little peice for the remote, but you can just put the wire through the little hole & you're set.
- Amp is modded to handle 1 ohm or up to 18 volts daily. Not sure if you should mix the 1 ohm load w/the 18 volts, but why not try, these amps are BULLETPROOF.
- 100% working order, been through 2-3 installs. All local SoundCheck installs, never abused.
Asking $360 shipped. $325 local pick up.
OR BEST OFFER.
Come on, you can get close to 3k out of this amp @ 1 ohm.. drop it even lower than 1 ohm & it's stable, if you got the electric.
Where else you gonna find an amp like this, this cheap? $250 is the deal.
J31Rob
CarTune Netwerk
J31Rob
Indiana
abdulwq
