I currently have a slightly used Fosgate T400-4 for sale. I will post pictures up later tonight. I am looking for $180.00 shipped for this amp. But if you have a JL Audio 300/4 that you would like to trade let me know. Also if I am able to find a 300/4 cheaper than the price I have posted I will let it go for that.
Here are the specs:
Rated Power
continuous power 60W x 4 @ 4-Ohms RMS
100W x 4 @ 2-Ohms RMS
200W x 2 @ 4-Ohms bridged RMS
2-Ohms x 2 bridged Stable
Bridgeable Yes
Efficiency (average) 69% @ 4-Ohm
68% @ 2-Ohm
Crossover Controls Front High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Front Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Rear High-Pass (HP): 50-500Hz 24dB/octave Butterworth
Rear Low-Pass (LP): 50-500Hz 24dB/octave Butterworth
Tone Controls Front Channels - Punch EQ
Treble: 0dB to +12dB @ 12kHz
Bass: 0dB to +18dB @ 45Hz
Rear Channels - Punch EQ
Signal Input Front Low level: 1 RCA pair
Rear Low level: 1 RCA pair
Signal Output n/a
Power Input Connector Block
Power Wire Gauge 4 AWG
Speaker Output Connector Screw terminal barrier strip
Speaker Wire Gauge 8 AWG to 18 AWG
Heat Sink Type Cast aluminum
Cooling Convection
Remote Controls Optional Remote Punch EQ
(overrides rear channel built-in Punch EQ)
Visual Indicators Power
Thermal
Protect
Circuit Topology Class Class A/B
Frequency Response 20Hz to 20kHz +/- 1dB
Shipping Weight 11.90 Lbs.
(5.39 Kg.)
Dimensions (HxWxL) 2.14 x 8.14 x 13.66 (in)
5.42 x 20.68 x 34.69 (cm)
The PVC sheets states..........
75x4 @ 4 Ohms
126x4 @ 2Ohms
251x2 @ 4 Ohms
Here are the specs:
Rated Power
Bridgeable Yes
68% @ 2-Ohm
Signal Output n/a
Cooling Convection
Thermal
Protect
(5.39 Kg.)
75x4 @ 4 Ohms
126x4 @ 2Ohms
251x2 @ 4 Ohms
