Sold FS: Reference Hi-Fi A90 - $75 OBO
sundownz
Pro Seller
Supporting Vendor
Shipped in Continental 48 states.
This amplifier has been tested on the bench to operate normally but there is NO FURTHER WARRANTY IMPLIED OR EXPRESSED beyond that this amp will work when you receive it.
Compact little amp - seems to do at least close to rated power.
4ohm RMS power at 14.4V 90W x 2
2ohm Load RMS power at 14.4V 110W x 2
4ohm Bridged RMS power at 14.4V 180W x 1
Input Level 0.2~5V
High Level Input NA
Two Channel Input mode NA
CH-A filter mode HP-FULL-LP
CH-B filter mode NA
CH-A LPF 50~500Hz
CH-A HPF 50~500Hz
CH-B LPF NA
CH-B HPF NA
Frequency Response 10Hz~25KHz
THD at 40hm load 30% Rated Power
S/N Ratio >90dB
Channel Seperation >89dB
Minimum Load 2ohm
Overload protect System YES
ShortCircuit Test@ max power PASS
Overheat protect temperature 80C / 176F
Transparent Isolation Connector NA
HI-END Design NA
Components & PCB SMT & Double side board
Dimension (mm) 198 x 184 x 54
Dimension (inch) 7.8 x 7.2 x 2.1
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
