Sold FS: Rare AVI SL300 Subwoofers w/ chrome baskets
these are the specs I could dig up. I don't know how to post pics, if you can leave me your email address and I'll send them your way
MODEL AVI SL-300, 300 mm (12") SUBWOOFER DRIVER
APPLICATIONS This is a subwoofer driver for high performance sound systems.
Suggested operating range is 27 to 400 Hz.
PERFORMANCE 21 to 1080 Hz at -10 dB points, in optimum enclosure.
27 to 400 Hz at -3 dB points, in optimum enclosure.
500 watts music program material.
250 watts AES pink noise rating.
128 dB typical, in vehicle, with rated power.
102 dB typical, at 1 watt, in vehicle.
93 dB average, at 1 watt and 1 meter, in half space.
4 ohm nominal, 3.2 ohm minimum.
FEATURES Cast aluminum frame with cavity vents, black finish.
Extended and vented pole piece with integrated bottom plate.
Both top and bottom plates with CNC and black absorbing finish.
Yellow HX type woven fiberglass cone with linearity damped composite rubber edge.
Heavy duty gold plated brass terminals.
1995 g (70.3 oz) magnet.
65 mm (2.5") copper ribbon voice coil, OFC edge wound.
PHYSICAL 312 mm (12.3") overall diameter.
138 mm (5.4") overall depth.
272 mm (10.7") cut out hole diameter.
125 mm (4.9") mounting depth.
6.5 Kg (14.3 lbs) weight.
van2u
van2u
Vancouver
van2u
